What would be the first things to try if Aranet4 device is not pairing to Aranet4 application on mobile device?
Posted: 10.04.2021 11:15
Modified: 24.10.2026 02:02
Please first try:
- Set jumper switch in the battery compartment for Bluetooth service in OFF (down) position, then back to ON (Up) position;
- Put batteries in the correct polarization again inside the Aranet4 (both batteries in the same direction with + pole on the left side);
- Uninstall the Aranet4 app completely and delete/forget the paired Aranet4 device from Bluetooth connected devices on the mobile device;
- Restart the mobile device;
- Install again the application and pair the Aranet4 to the mobile device not via the Bluetooth devices menu, but only via the Aranet4 application.
airepurouy
Posted: 08.07.2021 16:40
Hi, I have seen that I can pair the device, but if I get disconneted, I need to remove the device and start pairing again.. Sometimes I need to reset my IPhone too! Is that OK or I am missing sth? Thanks!
airepurouy
Posted: 09.07.2021 05:44
Please check the firmware version of your Aranet4 and upgrade if needed according to instructions in adjacent topic: https://forum.aranet.com/all-about-aranet4/how-can-i-update-aranet4-device-firmware/
If this does not help, please contact [email protected].
tiho
Posted: 06.01.2022 13:00
I can't remove the app because one sensor can't connect, I have over 10 devices registered... Things like this need to be fixed on your side
Posted: 06.01.2022 13:12
Hi tiho,
Max number of sensors that can be paired to one Aranet4 app is 20. Consider pairing the sensor to another mobile device.
