Is there any smart application to read Aranet4 directly on PC?
fjm56
Posted: 19.01.2022 12:36
Modified: 24.10.2026 02:28
I tried to use the Android emulater to view my Aranet4 data on my Windows PC, but I couldn't get a Bluetooth connection on this emulater.
Posted: 19.01.2022 13:08
Currently, there is no Aranet4 app for Windows. You can search Github for some clients for Linux, f.e. https://github.com/Anrijs/Aranet4-Python.
stev
Posted: 13.03.2022 11:36
Has anyone got this to work? I have tried on a pi3b and a linux laptop. I get as far pairing but it won't connect.....anyone?
matthew1471
Posted: 15.09.2024 10:01
Just to add that Aranet4 library now switched to Bleak which works across platform.. so works fine on Windows :)
friendlyfire
Posted: 20.01.2022 11:18
There is a a progressive web app (PWA) for interacting with Bluetooth LE (low-energy) sensors using a web browser.
Incidentally the programming example uses the Aranet4 BLE device. You have to use a browser the supports PWA i.e. Chrome.
Posted: 20.01.2022 12:07
Thank you for sharing the information!
friendlyfire
Posted: 20.01.2022 12:33
A remark from my son, he is a webdeveloper for SEO: The used toolset is unneccessarily complicated and probably not all tools are needed.
fjm56
Posted: 21.01.2022 05:20
Thank you very much for your kind information.
But unfortunately, somehow on my system, Windows 10, Chrome, YOGA7/Lenovo, I failed to read Aranet4 even with this PWA, though I have a Bluetooth connection.
friendlyfire
Posted: 21.01.2022 10:22
Modified: 21.01.2022 10:23
@fjm56 - You probably have not searched the web, I guess.
There is a sort of workaround which you can find, for example, on stackoverflow.
Last contribution on that page.andrejss
Posted: 28.01.2022 13:38
Modified: 28.01.2022 14:36
It is possible somehow use WiFi connection that is available in Aranet4 Pro?
Thank you.
Posted: 28.01.2022 13:45
There is no Wi-Fi connectivity in Aranet4 Pro. The sensor communicates with the Aranet Pro base using higher frequency range: 868...923 MHz depending on the region.
andrejss
Posted: 28.01.2022 14:28
Thanks for the responce.
Are you using own developed protocol? Or something like Z Wave, Zigbee, etc.
Posted: 28.01.2022 14:35
Aranet uses its own developed protocols.
friendlyfire
Posted: 28.01.2023 09:41
Modified: 28.01.2023 09:56
Unfortunately, since the firmware update to v1.2.0, my Aranet4 is not found anymore by the Windows PWA-app "Sensor Pilot",
although the device can be coupled using the common procedure with the PIN.
The author mentioned the relevant changes as an issue, but it doesn't seem that the Bluetooth-UUID filters in the app have been adjusted accordingly.Would be nice if someone can confirm this and probably give indications/directions how to fix this.
Posted: 30.01.2023 07:52
The PWA-app "Sensor Pilot" is not developed/supported by the Aranet team. Either way, we have asked the developer if it is in their plan to make the needed changes to allow connectivity again.
bimbam
Posted: 15.09.2024 18:35
Modified: 15.09.2024 18:36
Home Assistant has an integration for Aranet4.
It communicates with the device via Bluetooth and can read all values from from the Aranet4 and use it for any display (e.g. on PC) or automation.
Bluetooth range can be extended using a ESP32 running a Bluetooth proxy or using 2nd Generation Shelly devices with Bluetooth.
romanshevchuk
Posted: 21.10.2026 13:25
For anyone still looking: I made an unofficial Windows app for the Aranet4. It has tray flyout view and a simple dashboard, keeps history (you can also import the xlsx from the phone app), and alerts when CO2 gets high.
Only tested on my own Aranet4 / Windows 11, so bug reports and feature ideas are welcome (here or on GitHub).
Microsoft Store: https://apps.microsoft.com/detail/9N027HRZXSMH
GitHub: https://github.com/romanshevchuk/deskair-aranet4
