Aranet 4 home is not beeping(buzzing).
wenonot
Posted: 11.01.2024 09:09
Modified: 24.10.2026 02:18
Hi.
10 days ago I got my first Aranet 4 home.I've set an 1 minute interval of the sesor and co2 indication mode to custom to beep when it is over 1000 ppm.
Till yesterday evening, everyting worked fine as intended and kept beeeping above 1000ppm.
But this morning for some reason it stopped beeping.
It still has the speaker icon showing on the screen of the device.
Should I in someway reset the device? If so how should I reset the device?
( This morning I deleted an aranet 4 app from a very old device that I've once tried to link to but failed. This seems unrelated but I can think of no other action I took.)
Hope to hear from you soon.
Best,
Chae.Aranet4 2108E
317960135310, rev 12
Frimwaree v1.4.14Fixed!!
As a last attempt I disconnected the device from my phone, pull out the batteries and put the batteries back in. And the beeping(buzzing) came back. : )
Since it is working properly I'd like to add that,
Since I got Aranet 4 I get much better quality sleep everynight. Thanks for making the device available.
Best, Chae
Posted: 11.01.2024 10:02
Thanks for the update, if this keeps happening please contact [email protected] and we will see what can we do about it.jan.e
Posted: 17.04.2024 08:40
Hi there, I had the same behavior - it just stopped buzzing no matter what the buzzer settings were. I could remedy the problem by just taking out the batteries and thus forcing Aranet4 to reboot. (I didn't need to disconnect it from my phone)
Would be nice though if you could investigate and fix that bug in one of the next firmware versions :-)
wenonot
Posted: 17.04.2024 09:29
Hi.
Jan.e,
So I guess disconnecting the device from my phone wasn't necessary after all, and a reboot was all that it needed.
Thank you very much for sharing your simple method.
And I also do hope we get an update soon or later. :-)
Best,
Chae.
